В бизнес-объекте храниться более 70 млн записей.
При открытии реестра выдает сообщение с ошибкой вида
An error occurred while executing the command definition. See the inner exception for details.
В детализации ошибки
System.Data.Entity.Core.EntityCommandExecutionException: An error occurred while executing the command definition. See the inner exception for details. —> Npgsql.NpgsqlException: Exception while reading from stream —> System.IO.IOException: Unable to read data from the transport connection: Operation on non-blocking socket would block. —> System.Net.Sockets.SocketException: Operation on non-blocking socket would block at System.Net.Sockets.Socket.Receive (System.Byte buffer, System.Int32 offset, System.Int32 size, System.Net.Sockets.SocketFlags socketFlags) [0x00016] in :0 at System.Net.Sockets.NetworkStream.Read (System.Byte buffer, System.Int32 offset, System.Int32 size) [0x00065] in :0 — End of inner exception stack trace — at System.Net.Sockets.NetworkStream.Read (System.Byte buffer, System.Int32 offset, System.Int32 size) [0x000ac] in :0 at Npgsql.NpgsqlReadBuffer+<>c__DisplayClass34_0.g__EnsureLong|0 () [0x00252] in <3d1c653e222242cb971134634b2a23a5>:0 — End of inner exception stack trace — at Npgsql.NpgsqlReadBuffer+<>c__DisplayClass34_0.g__EnsureLong|0 () [0x00371] in <3d1c653e222242cb971134634b2a23a5>:0 at Npgsql.NpgsqlConnector+<>c__DisplayClass160_0.g__ReadMessageLong|0 (Npgsql.DataRowLoadingMode dataRowLoadingMode2, System.Boolean readingNotifications2, System.Boolean isReadingPrependedMessage) [0x00452] in <3d1c653e222242cb971134634b2a23a5>:0 at Npgsql.NpgsqlDataReader.NextResult (System.Boolean async, System.Boolean isConsuming) [0x008c6] in <3d1c653e222242cb971134634b2a23a5>:0 at Npgsql.NpgsqlDataReader.NextResult () [0x0001f] in <3d1c653e222242cb971134634b2a23a5>:0 at Npgsql.NpgsqlCommand.ExecuteReaderAsync (System.Data.CommandBehavior behavior, System.Boolean async, System.Threading.CancellationToken cancellationToken) [0x0031a] in <3d1c653e222242cb971134634b2a23a5>:0
Ограничения по времени, которые регулируются в конфигах или bi в целом не может открывать реестры с таким объемом записей ?
